Torque Doublecheck
Torque Doublecheck
Okay, I've seen on here that the torque for the drive axle nut is 81 ft lbs and the hub bearing bolts are 85 ft lbs. I've seen on other sites where the axle nut is ridiculously high, at around 184 ft lbs. Since these are so far apart, which is everyone using to torque their axle nuts?
