Vibration front passenger side
Don't refuse to jack the corner up and test the hub based on what you thought you understood on the internet.
Go ahead and throw parts around without checking if they are actually bad, fine with me.
You should change hubs in pairs, at least to save yourself future grief.
Last edited by donbrew; 04-04-2014 at 03:22 PM. Reason: I was tired and sounded nasty
rear hubs can be checked with the wheel off the ground hold the top and bottom of the tire and wiggle it if it moves then rotate the tire and listen for grinding noise , now if you her that , remove the tire and the brake drum and wiggle the hub itself and rotate it, if it still makes a noise , replace the hub, and as Don suggested , replace hubs in pairs
If one is worn the other is right behind it.
Hey johnnylb,
Welcome to the forum! We’re sorry to hear that you are experiencing vibration in your vehicle. Please let us know if you would like any extra assistance. We will be glad to look further into this concern for you. If needed, please send a PM referencing your concern.
Kristen A.
Chevrolet Customer Care
Kristen A.
