Vibration front passenger side
Old 04-03-2014, 04:37 PM
johnnylb's Avatar
2007 HHR. Vibrates above 40 mph and turning left. Replaced hub. Rotated tires. Still there. Not sure now. Bueller???
johnnylb is offline
Old 04-03-2014, 04:44 PM
LawDog88's Avatar
Welcome.
Front or back vibrates ?
LawDog88 is offline
Old 04-03-2014, 05:18 PM
The OTHER hub?
donbrew is offline
Old 04-03-2014, 07:06 PM
johnnylb's Avatar
Front. I didn't change the other hub. Everything else I have read, if you turn to the left and vibrates worse, it is your right side. Definitely feel it on the right. Nada on driver's side.
johnnylb is offline
Old 04-04-2014, 06:45 AM
Don't refuse to jack the corner up and test the hub based on what you thought you understood on the internet.
Go ahead and throw parts around without checking if they are actually bad, fine with me.
You should change hubs in pairs, at least to save yourself future grief.
Last edited by donbrew; 04-04-2014 at 03:22 PM. Reason: I was tired and sounded nasty
donbrew is offline
Old 04-04-2014, 07:41 AM
pbatmen's Avatar
i would check three things, 1. check sway bar links, 2. tie rod ends, 3. maybe you threw a weight of a wheel and it became unbalanced. all three you can check at home in the driveway/garage.
pbatmen is offline
Old 04-04-2014, 03:08 PM
rear hubs can be checked with the wheel off the ground hold the top and bottom of the tire and wiggle it if it moves then rotate the tire and listen for grinding noise , now if you her that , remove the tire and the brake drum and wiggle the hub itself and rotate it, if it still makes a noise , replace the hub, and as Don suggested , replace hubs in pairs
If one is worn the other is right behind it.
Oldblue is offline
Old 04-04-2014, 10:03 PM
johnnylb's Avatar
Thanks all! Don.. You tha man! Should have changed in pairs. The only reason I didn't was due to the place only having the one and time constraint. It was the driver's side front making the noise.
johnnylb is offline
Old 04-04-2014, 10:15 PM
Cool!
donbrew is offline
Old 04-05-2014, 06:27 PM
Hey johnnylb,
Welcome to the forum! We’re sorry to hear that you are experiencing vibration in your vehicle. Please let us know if you would like any extra assistance. We will be glad to look further into this concern for you. If needed, please send a PM referencing your concern.
Kristen A.
Chevrolet Customer Care
ChevroletCustomerService is offline
Quick Reply: Vibration front passenger side
