CV shaft inner joint issue
I’m having some issues here.....passenger side CV shaft....how much “up and down” play should it have inside the transmission? My issue is that the CV shaft has play so the weight of the CV is pulling down on the axle seal causing it to leak. Is this a transmission issue? Any fixes without changing the Tranny?I’ve changed the CV shaft, both seals TWICE. Still leaking. I’m at my wits end, I need help!!!
There must be something in there. There are 2 clips, 1 in the cup and 1 on the end of the shaft.
I am assuming that you are using the original stub. I guess you have to pull it out and look inside
