Hard Shifts
Thank you very much! I'll go throgh and clean the MAF, test fuel pressure, and smoke it tomorrow. I got lucky with my 97 Ranger last week and a MAF cleaning cleared the same code. (Fingers crossed)
Don’t dismiss P0171 as a vacuum leak. There are other possibilities. It means “Fuel Trim System Lean”, i.e., the system thinks the system is defaulting lean, and that the (successful) adjustment to get to the correct a/f is excessive.
Do you ever run E85? NOT a bad thing. Good stuff. But knowing that can help diagnose. GM FlexFuel very rarely get confused about the ethanol percent in the tank. That can result in P0171 or P0172. AVOIDING THE USE OF E85 WIILL NOT PREVENT THIS PROBLEM, so don’t let anyone blame the use of E85. There’s at least one TSB on it. Ask me how I know.
But I wouldn’t worry about that yet.
I would first verify correct fluid level in the transmission. Then I would clear the codes and see if the hard shifting stops (at least until the code sets again.)
BTW, I definitely agree with previous advice to clean the MAF sensor and throttle body.
Also, a bad #1 O2 sensor can give you trouble with a/f readings.
PSA, alway shut down when refueling, but especially with a GM FlexFuel car.
While test drving it this morning, I did get new codes, and the CEL came on.
The ECM now has P0700 (Trans Control Sytem (MIL Request) in both pending and confirmed states.
The TCM now has P0842 (Trans Flud Pressure Sensor/Switch "A" Circuit Low) in both pending and confirmed states.
Check for chaffed wires near the TCM , if the transmission fluid is full, consider replacing the TFPS and the shift solenoids inside the transmission cover on the drivers side.
there might be melted connectors or other issues with the transmission
Thanks for the tips!
