Service traction control light
Got htis about a week ago. Service Traction control, Service ABS, Service ECS. all lit up at the same time. NO CEL. ligts went out about 30 secs. later. Then happened again this morning same senario. Again no CEL. '09 SS 112,000 miles. auto trans. Front Wheel bearings replaced at 90,000 miles . Thanks
What were the driving conditions or scenario when these warnings lit up ?
FYI. I would pull the codes and check. Not all codes light up the CEL on the 1st occurrence. You may have a stored or pending code.
I did check the codes this morning , there were no codes
First time 10 mins into my commute to work. this morning about 20 mins into my commute to work. First time ,driving through and intersection about 30 mph. This morning driving at about 60mph
If it is your battery, watch what you buy. The one I replaced had one with an 18 month warranty. I lasted about 2 years.
