Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Anyone ran taller tires?
Old 09-14-2011 | 08:14 PM
halloffame's Avatar
I checked the diameter of the HHR's tires 215/55/16's are 25.3" tall. Anyone tried a taller tire in the 26.5" to check MPG?
Old 09-14-2011 | 08:24 PM
The lower spring perch on the front strut is going to limit you to 26" or just a hair over. Don't think you will fit 26.5"
Old 09-14-2011 | 08:38 PM
halloffame's Avatar
Your right, just went outside and checked.. it is a fingers width clearance now. Well shims or something could cure that. Plenty of room in the rear. Taller tire would throw the final drive ratio way down.. and rpm's.
Old 09-14-2011 | 08:39 PM
goetylsd's Avatar
I am running 225/50/17 BF Goodrich Traction T/A tires on the factory 17" 2LT wheels. The factory wheels call for 215/50/17, so I am running a little bit taller than normal. As they are now, there is just enough room for them, they do not cause any issues. Anything taller I am sure would start to cause rubbing, etc.
Old 09-14-2011 | 09:09 PM
halloffame's Avatar
That is a 25.9" ..Do you notice any difference in mileage, RPM is how much less?
Old 09-14-2011 | 10:39 PM
tracy waddell's Avatar
We have a member out here on the west coast, that goes by the name "PROSTREET". He is running the widest on tallest rear tires you can stuff inside the rear tubs. Send him a PM and see what size tires he has.
Old 09-17-2011 | 06:04 AM
HHR01844's Avatar
im running 225/55/16 on steelies instead of the 215/55 that were on there and im not noticing much of a difference other than the ride feels smoother (maybe its because theyre new?)
jcgc50
Tires & Wheels
11
07-19-2010 09:27 AM
krabriter
04-17-2010 08:07 AM
dirttoo
Tires & Wheels
08-24-2008 11:53 PM
