07 HHR no crank sometimes
Old 02-12-2022, 04:52 PM
  #41
That appears to be an aftermarket remote start / security device, not factory
https://www.the12volt.com/installbay...asp?tid=131309
Oldblue is offline
Old 02-12-2022, 04:59 PM
  #42
https://www.google.ca/search?q=inlex...PRGyAaJqUH18BM
One of these might help
Oldblue is offline
  #43
If there is that much gas in the oil it is a good thing you can't start it. Have it towed to a mechanic; you have major trouble.
donbrew is offline
Old 02-12-2022, 05:05 PM
  #44
Jallen8482's Avatar
It is a very small box. Im assuming its a gps locator from a buy here paybhere or something. It is only wired to two wires and thats all.
Jallen8482 is offline
Old 02-12-2022, 05:25 PM
  #45
Perhaps this will help
Oldblue is offline
Old 02-12-2022, 05:28 PM
  #46
Jallen8482's Avatar
If it helps the wires the box was wired into the red and white wire that was broken. Goes to the ecm/tcm fuse on the bcm. 10amp. Im wondering if it sparking and arcing may have somehow damaged one of my computers in the car.
Old 02-12-2022, 07:16 PM
  #47
Maybe something that controls the fuel pump. Malfunctioned and flooded the engine with fuel?
RJ_RS_SS_350 is offline
Old 02-12-2022, 09:35 PM
  #48
Am I the only that noticed the crankcase full of gasoline? I do love being ignored.
donbrew is offline
Old 02-12-2022, 10:43 PM
  #49
Jallen8482's Avatar
The oil seems to be a quart overfull. It smells like gas. From what i have read that is a common problem on these engines. Im guessing that has nothing to do with why the fuel pump wont prime and the starter wont turn over at the same time. They both work but the car isnt telling them to work when i turn the key.
Old 02-13-2022, 06:21 AM
  #50
If the fuel pump won't prime, where did all the gas in the oil come from?
Greybeard999 is offline
Quick Reply: 07 HHR no crank sometimes
