08 hhr ls
08 hhr ls
I purchased a new '08 LS back in July of last year. I was very happy with this car until about 5 months ago, that's when it all started down hill. I brought the car back (7) times within a couple of months for the same problem - TPM system problems. They replaced all the sensors and the receiving unit that is inside the car. This did not solve my problem. The sensors continued dropping out. One morning on the way to work, my instrument cluster froze at 45 MPH. That had to be replaced. They also replaced the steering column because of excessive noise coming from that area. Also, when it is cold outside, the front suspension make a lot of noise, to solve this, they replaced the sway bar ends and bushings. Well, this did not solve the problem!
I filed suit against GM based on Michigan's Lemon Law and won the law suit. As of yesterday, I no longer own the HHR.
