2.2 or 2.4?
2.2 or 2.4?
Looks like I'm about to get a 2010 HHR. I looked under the hood and didn't see any stickers with the engine size on them. How do you tell which engine it has in it? My mom had an older HHR and there was a sticker under the hood that said that it was a 2.4.
Welcome to the site
There should be a decal on the hood. If it's not there I would suspect that the hood has been changed.
I would look for signs of body work.
To answer your question look in side the glove box. You will find a tag of rpo codes.
LE5=2.4
L61=2.2
LE5=2.4
L61=2.2
check the RPO codes on the sticker inside the glove box, looking for the ones starting with L - ie these ones for a 2008:
L61 Engine, ECOTEC 2.2L DOHC 16-valve 4-cylinder SFI
LE5 Engine, ECOTEC 2.4L DOHC 4-cylinder SFI
If yours differ, do a quick google search.
More info can be found at
https://www.chevyhhr.net/forums/gene...o-codes-10645/
GM offers a exact look alike Parts Dept. accessory option and I have seen one on a 2.2L 1LT HHR.
It is a bolt on where the factory is a weld on.
SF
