2.2 vvt engine
P0974 mean “1-2 Shift Solenoid Control Circuit High Voltage.” Broken transfer tubes can’t cause that. A short in the wiring or more likely the solenoid coil
The transmission problem should allow you to negotiate a very good price. WAY less less than a well running car.
VVT doesn’t improve the fuel economy all that much. DOES add complexity. Now, if you live someplace where you can buy E85 cheap, like California, that’s a good reason to favor a FlexFuel car. But in most places, you can’t. Then just buy the better car.
