2.2 vvt engine
Old 08-31-2024 | 01:52 PM
Gearhead1's Avatar
2.2 vvt engine
Did the 2009 have variable valve timing?
Old 08-31-2024 | 01:55 PM
yes. can't have FlexFuel without it.
Old 08-31-2024 | 01:57 PM
Gearhead1's Avatar
Originally Posted by donbrew
yes.
ok….reason ask….Im looking at maybe buying one that had transmission issue P0974 code….but I like the better mileage of the vvt
Old 08-31-2024 | 02:10 PM
That means stuck 1-2 shift solenoid.
Old 08-31-2024 | 02:15 PM
Gearhead1's Avatar
yes but guys says no forward gears….tubes maybe?
Old 08-31-2024 | 02:18 PM
Gearhead1's Avatar
I’m wondering if metal tubes are broke loose inside the pan? Wonder if that would explain no forward gears and the P0974 code also
Old 08-31-2024 | 03:08 PM
While you’re at it change the solenoids and the tubes and filter , fluid . Might as well , your hands will be dirty anyways.
Old 08-31-2024 | 03:22 PM
Gearhead1's Avatar
looking at buying not mine yet
Old 08-31-2024 | 04:19 PM
Go for it! Easy fix!
Old 08-31-2024 | 06:01 PM
PulpFriction's Avatar
No.
P0974 mean “1-2 Shift Solenoid Control Circuit High Voltage.” Broken transfer tubes can’t cause that. A short in the wiring or more likely the solenoid coil
The transmission problem should allow you to negotiate a very good price. WAY less less than a well running car.
VVT doesn’t improve the fuel economy all that much. DOES add complexity. Now, if you live someplace where you can buy E85 cheap, like California, that’s a good reason to favor a FlexFuel car. But in most places, you can’t. Then just buy the better car.
