Is the 2.2 a weak engine?
Old 08-02-2021, 09:17 PM
miles solo's Avatar
The 2.2 has enough power. Seems to me the cruise control induced downshift and the associated roar and jump in rpm is the result of the automatic’s design. It has a big big step from 3rd gear up to 4th gear’s overdrive ratio.
miles solo is offline
Old 08-03-2021, 02:54 PM
PulpFriction's Avatar
Originally Posted by Oldblue
The front guide failure almost always is because the top bolt unscrewed or broke, the replacement bolt has pretty much resolved that problem
I ain’t saying that ain’t so, and I have more limited experience, but my front guide was broken (still largely intact and in place) and the bolt was tight and unbroken. I’ve also seen a couple pics of the guide gone and the bolt beat up and worn by the chain but tight and unbroken. So it’s possible that at least in some cases, the bolt got broke ‘cuz the guide failed.
Nevertheless, I did replace with the redesigned bolt (which I learned about here, thankyouverymuch,) because it can’t become a wrench in the works, regardless of what caused what.
PulpFriction is offline
taz3
10-23-2015 01:05 PM
Grizzly old man
08-11-2014 10:59 PM
11hhrlt
03-17-2014 07:21 AM
zabadubarbara
08-09-2013 11:00 PM
JoeDickinson
06-05-2012 04:16 PM
Quick Reply: Is the 2.2 a weak engine?
