2007: Can cigarette port 12v be tapped to add 2nd port?
#32
All of the "unused" fuses on the BCM are on the RAP relay; meaning switched and stays alive until the driver door is opened then closed, like the radio.
#35
#36
The problem is that both of the factory outlets are always hot. If you want switched you need to add a wire from the BCM. That is what "ignition/ door switch" means, on the RAP circuit.
#37
Re: The diameter of the in-dash power port vs the rear console power port:
On closer inspection today, the center console power port had 2 pennies lodged inside preventing the use of the port! - Sorry. Never mind! I deleted my "help" question.
And now my tire inflator AND phone can be plugged in now. My apologies for not discovering that earlier.
I hope I didn't damage the 15 amp circuit for the in-dash port because it burned out two 15 amp fuses before I stopped inflating the tire.
Thanks for the quick reply, Oldblue!
I think the 2nd blown fuse turned off the engine at the same time! Is that usually possible? Unless in my haste (it was raining at the time, yesterday) I forgot to turn on the engine that 2nd time? IDK.
second case in this thread resolved. I’m closing this one!
weekendwarrior
01-20-2011 08:35 PM
