2007 HHR Transmission issues
I’m thinking just run it through the gears around the block to flush out the fluid and drop the pan and filter again, so 14 to 21 quarts 2 or 3 gaskets and filters, and an afternoon of prayer for the rest of the transmission and torque converter to flush out!
I wonder how well it would work to run a line into a pail and another to a jug of transmission fluid to the cooler lines?
That might cook the clutches and the pump!
We used to pull the line coming out and run it into a graduated 5 gallon catch bucket pouring ATF in at about the same rate. Works well.
