2007 HHR Whining and Sticking In steering
Old 10-20-2020 | 06:28 PM
SheckyB's Avatar
Hey Guys My steering is whining and sticking Could this be the Rack and Pinion??
Old 10-20-2020 | 11:41 PM
Could be the wife grabbing the wheel while whining.
Could be rack & pinion.
Could be LCA bushings.
Could be a rock under a tire.
Could be a dying EPS motor.
Could be tie rod ends.
Could be bad wheel bearings.
Could be ball joints.
I can't think of a part that would produce a whine.
Old 10-21-2020 | 06:26 AM
Cat Man HHR's Avatar
Don you forgot the power steering pump low on oil.
Old 10-21-2020 | 06:28 AM
The EPS motor is up under the dashboard, where is the whining noise coming from?
I can’t put a whining noise to any of the front end parts, except possibly the hubs, and or brakes.
Old 10-21-2020 | 06:52 AM
Yes...maybe...or something else.
You should give a better description. Like the when, how and where the noise is occurring.
Old 10-21-2020 | 09:36 AM
geg's Avatar
geg
I am not an expert in electric power steering, but I am a little familiar with electric motors.
The abnormal sound in the electric motor comes from the bearings 90% of the time. This also explains the uneven performance.
I would venture to suggest that the bearing (bearings) have worn out due to: rust, pollution, lack of lubrication, poor-quality assembly, and some other reasons.
An autopsy will reveal ...
There are fake parts. I don’t know about the USA, but in the whole other world this is a common phenomenon. If the amplifier motor has been replaced in the past, it is possible to install a low-quality product that dies out slowly.
Old 10-21-2020 | 10:05 AM
SheckyB's Avatar
From what I have read it does not have fluid but that's what it sounds like Low fluid and what about the sticking.....And rack says has to be programmed is this True??
Old 10-21-2020 | 10:18 AM
Lonwane's Avatar
Shecky,
Please do an internet search on 'electric assist power steering'.
This will help to familiarize yourself with how this system works and may redirect your questions.
As for the steering rack being "programmed", NO.
It is not a computer, just a mechanical device.
Old 10-21-2020 | 11:08 AM
SheckyB's Avatar
The Whine and sticking happen when I turn the wheel it sounds like low PS fluid but it does not take fluid ... Do you know anything about reprograming the rack does this need to be done If not what happens?
Old 10-21-2020 | 11:11 AM
SheckyB's Avatar
the auto shop wanted 90 -199 to program rack so your saying not needed?
