2009 Fog light help
2009 Fog light help
My HHR was built with fog light , apparently the front bumper was replaced and has one vent looking cover ... I want to go get a set of fogs to add back on but looking in the opening I see no wire or bulb socket inside. Where does the actual fog lamp wiring or pigtail connect so I can check? I can see the wiring going to the marker light but not seeing anything else unless I am looking in the wrong spot (wheel well area ) ??? thanks for any help and pictures would be great as youtube doesnt show anything either.
https://www.chevyhhr.net/forums/main...t-bulbs-18454/
Some information look around , remove the plastic fender liners, pull the front bumper cover.
I reached up and think I found a plug so apparently I will need that pigtail for the bulb socket also... Hopefully the salvage yard still has all those HHRs sitting around... Just not looking forward to the rain but guess I have to suffer a bit to prevail !
anything special to get or tips when pulling? Mine is missing everything as far as the fog lights and any adjustment stuff. What tools will I need to have on hand ( I dont want to lug a full box, just a pocket full.
Oldblue recommended these to me, very handy.
https://www.harborfreight.com/panel-...ers-63699.html
doesn't look like it, GM's pretty good about showing everything in their diagrams (one of the reasons I like their catalog)... that's all it shows with the fog lamp
