2009 Fog light help
Old 06-12-2022, 04:34 PM
The 2008, 09, 10 SS and the 2009, 10, 11 LS/LT’s had the window switches in the driver’s door.
The 2006, 07, 08 had the console windows switches.
Oldblue is offline
Old 06-14-2022, 04:54 PM
heathenhhr's Avatar
Originally Posted by Bonez
Ran to 2 salvage yards (130 mile round trip....whew ) didnt find any fogs but did snag a set of covers for now, also got 2 mirror covers, the steering wheel switch a rubber boot for throtle body as mine is doing some chalky nasty rubbing off , and some door handle inserts ( dont fit my 09, did different years change the handle sizes ? Mine are oval shaped where the ones I pulled are more oblong ? ) for a grand total of $4
how hard are those mirror covers to pop off?
my plan was to vinyl wrap mine because I figured they'd be a pain to try to swap (I have chrome, I want black)
heathenhhr is offline
Old 06-14-2022, 05:57 PM
You tip the mirror glad and use a screwdriver to release the plastic clips from the bottom, then move the mirror and release the top
Oldblue is offline
Old 06-15-2022, 01:47 AM
Bonez's Avatar
I popped these off from the top down.... guess it worked either way as nothing broke.... I myself hate the chrome and have some carbon fiber wrap I wanted to try on a set I could swap
Bonez is offline
Old 06-15-2022, 04:54 PM
Bonez's Avatar
New fogs came in, supposed to rain tomorrow so may not get them installed til this weekend?
Bonez is offline
Old 06-15-2022, 05:13 PM
  #26
Bonez's Avatar
I went out and popped the drivers side cover off and plug is there for fogs, and the marker was unplugged so got that plugged in. I got on the passenger side and popped the wheel well cover up and found the fog wire wound up on the loom up high, after getting it un tangled and all there is another loom coming off the fog wire with this sensor on it, where does this thing mount? Im assuming on the metal frame behind the bumper under the headlight? If anyone has a picture of where it goes would be great....also what sensor is this anyways? Thanks for your help.
Bonez is offline
Old 06-15-2022, 05:28 PM
  #27
PulpFriction's Avatar
I just realized I’ve never used fog lamps in my life, even though I’ve had them on several cars and still do on two.
Maybe I should try them out just to see what all the fuss is about.
PulpFriction is offline
Old 06-15-2022, 05:30 PM
  #28
If that is the outside temperature sensor, then I believe it's supposed to be on the "frame rail" on the right side. (I think Donbrew knows if this is correct)
Here's a pic that shows the location. Somewhere around the yellow circle.
firemangeorge is online now
Old 06-15-2022, 05:41 PM
  #29
That's right for 2006-2009. After that it was just hanging around by the radiator.
That is what that is.
donbrew is offline
Old 06-15-2022, 05:51 PM
  #30
Bonez's Avatar
FMG thank you, exactly where I thought due to the reach and fog plug.
DB, I remember seeing it on the 08 above the radiator but this wont reach there, and FMG showed exactly where I assumed it would go.
Pulp, youll be amazed, I love using the fogs as they light up the sides/shoulders.... and actually help to see the lines as well as the pavement at night.
Bonez is offline
Quick Reply: 2009 Fog light help
