2009 HHR 1LT-should I buy it?
Old 02-15-2019, 09:10 AM
Djjfoxhunts's Avatar
Update: I didn’t buy the 2009. The owner wouldn’t let the car be checked out even though it would have been at my expense. I passed. If the car were local, maybe I would have made a different decision. Anyway, I’m keeping the 2010. I’ve posted a thread in the correct (I think) forum for repair questions. Thanks to everyone for their advice.
New member, 1st post.
I’m considering buying a 2009 HHR 1LT with about 8800 miles, and yes, the mileage is accurate. It was owned by the first owner then garaged for a couple of years by that owner. Second owner bought for wife, but she wanted something bigger so garaged for another couple of years. He’s now selling it. Carfax verifies information re car.
Is buying this a good idea or am I just asking for trouble? If yes, what should I look for as far as problems go?
My current car is a 2010 HHR LS with about 120,000 miles.
Thank you for advice.
Djjfoxhunts is offline
Old 02-15-2019, 09:50 AM
Welcome to the site, snap it up! Yes sitting can be a problem, but it hasn’t been that long.
inspect the fuel lines for corrosion, after you get it, change the engine oil and filter, drain and replace the Dexcool in the cooling system.
I doubt there would a flat spot on the tires , but be prepared to purchase new tires.
Oldblue is offline
Old 02-15-2019, 09:56 AM
Thanks for the response.
What do you think the price should be?
My son and I are in disagreement on this. My 2010 needs about $1500 in needed but not unexpected repairs. My son thinks I should fix the 2010. I kind of want to buy the 2009 and sell the 2010.
I’m trying to be practical and make the best financial decision.
Old 02-15-2019, 10:00 AM
Silverfox's Avatar
Sounds like a Rare find.
1. I would change All Fluids Immediately.
2. How much gas is in the car? It would most likely be totally expired. Drain or Syphon out as much as possible then fill tank.
3. Consider replacing the tires after careful inspection. Check Air pressure in the spare. S/B 60 psi.
4. Consider Replacing the Battery after having it checked. See if you can determine the age.
5. Have a good look underneath for any leaks and also corrosion.
This would be a good start. Drive car for a while to see if there are any other issues that show up.
Silverfox
Silverfox is offline
Old 02-15-2019, 10:04 AM
Me?, I would fix the 2010, buy the 2009 and drive them both!!
But there is no cure for my HHR affliction!
How much, KBB
https://www.kbb.com/chevrolet/hhr/20...category=wagon
Oldblue is offline
Old 02-15-2019, 10:09 AM
The car is 8 hours away from me, but he’ll meet me halfway. Since he’s willing to drive it 4 hours, I guess he feels pretty safe.
Everything you suggested will be done when I get it home.
My biggest worry is that all the rubber parts are possibly comprised and that could lead to major problems.
Old 02-15-2019, 10:11 AM
Unfortunately, keeping both isn’t an option
Old 02-15-2019, 10:16 AM
They don't use "rubber" anymore, this is the 21st century. 8,000 milesis enough to look at the LCA bushings etc. Still $1500 probably on either car.
donbrew is offline
Old 02-15-2019, 10:55 AM
Now my age is showing since I used the word rubber. I’m referring to any part that would be degraded from lack of use. If the long term sitting has caused degradation in lots of stuff, I might be looking at major problems down the road. How do you know unless you rip the car apart? So better to spend $1500 on which one, I wonder.
I’m obviously asking questions where I’m not 100% sure of what I’m asking. I’m not a mechanic, and I know just enough to be dangerous.
Old 02-15-2019, 11:00 AM
The rear LCA bushings are easy to change, and might still be ok!
Oldblue is offline
Quick Reply: 2009 HHR 1LT-should I buy it?
