Aftermarket foglights (WARNING)
Just wanted to let everyone know stay away from BLINGLIGHTS.Com on ebay for aftermarket fogs. In case you didnt already know.
They DO NOT fit the way they are described another online company tryin to make a quick buck.
I did just purchase from gummiesource on ebay a pair of factory OEM foglights that just snap into place in the front bumper.. LOOKS right out the show room!
Harness was also included!!!!
Pics coming soon...
Pics coming soon...
If it's the one I've seen, I could tell they were not "factory". The ones I saw stated just like factory and they show a picture of an HHR that is supposed to have their fogs on. But it's an 2LT and they have factory fogs already on.
You can make them work by mounting them to the dummy plugs, but they are not like the factory as far as the mounting.
No, to use the dash switch you would need to wire it into the fuse box and than have the ECM programmed to see the fog lights.
The plug and play kit comes complete with harness and a lighted switch to turn them on and off.
I put a set of them on and liked the way they fit, but didn't like the way they were wired. I modified it slightly so when the switch is on, it takes power from one of the headlight low beams and uses that to actuate the relay. That way they come on and off automatically and I don't have to forget leaving them on.
kvnmontano
Mods - Exterior
02-01-2009 01:27 AM
