AGM battery for HHR LT
Old 09-09-2019 | 09:10 PM
comandoed's Avatar
Can someone confirm if Duracell AGM Battery - Group size 47 (H5) can be used in 2007 HHR LT?
If yes, is it advisable?
https://www.samsclub.com/p/auto-grou...questid=213548
thanks. I read several threads but would like confirmation or not.
thanks
Old 09-09-2019 | 09:24 PM
Yes. I have a group 47 AGM from Sears in mine now.
Old 09-09-2019 | 09:34 PM
comandoed's Avatar
Cool. . . No vent tube issues, right?
Old 09-09-2019 | 10:34 PM
I ditched the vent tube. My understanding is that the AGM does not release gas. Installed in January of 2015, no problems.
Old 09-10-2019 | 04:35 AM
comandoed's Avatar
Thanks.
Old 09-10-2019 | 06:02 AM
comandoed's Avatar
When installing is there any special consideration with the battery current sensor module?
Old 09-10-2019 | 08:26 AM
Not sure what your concern is for that. Remove the negative cable first, reinstall the positive cable first, then the negative.
Old 09-10-2019 | 09:52 AM
comandoed's Avatar
I saw the following and wondered if it was relevant to HHR.
"some vehicles require an extra step to tell the vehicle that the battery has been replaced. Newer vehicles have a Battery Sensor Module or similar systems. These systems require recalibration with a scan tool if the battery is replaced. If the system is not recalibrated, the alternator might overcharge the new battery and cause the battery to fail soon after replacement."
https://www.knowyourparts.com/techni...agm-batteries/
Old 09-10-2019 | 11:13 AM
Hmmm... Yeah, I'm not sure for your year, I've never seen that here on this site. My 2009 didn't need calibration.
Old 09-10-2019 | 03:44 PM
Be careful not to touch the positive cable end touch the negative terminal.
It might be prudent to remove the fuse for the RDO #23 interior fuse panel .
My 2007 or 2011 did not require any scans after battery replaced
Quick Reply: AGM battery for HHR LT
