AGM battery for HHR LT
Can someone confirm if Duracell AGM Battery - Group size 47 (H5) can be used in 2007 HHR LT?
If yes, is it advisable?
https://www.samsclub.com/p/auto-grou...questid=213548
thanks. I read several threads but would like confirmation or not.
thanks
thanks
"some vehicles require an extra step to tell the vehicle that the battery has been replaced. Newer vehicles have a Battery Sensor Module or similar systems. These systems require recalibration with a scan tool if the battery is replaced. If the system is not recalibrated, the alternator might overcharge the new battery and cause the battery to fail soon after replacement."
https://www.knowyourparts.com/techni...agm-batteries/
Be careful not to touch the positive cable end touch the negative terminal.
It might be prudent to remove the fuse for the RDO #23 interior fuse panel .
My 2007 or 2011 did not require any scans after battery replaced
