Alarm horn not honking when doors locked with fob
Old 03-12-2020 | 11:13 PM
Well at least we know the horn does function...
On my 07 the horn doesn't sound on the first push of the lock button, that just locks the doors. Second push of the button arms the system and the horn sounds.
Greybeard- That can easily be changed in the DIC settings. I set mine to only Beep my Caddy Horns on 2nd push. Cause sometimes I don't need to announce I'm locking my buggy.
Old 03-13-2020 | 08:23 AM
This is what I said...
Old 03-13-2020 | 09:22 AM
jjoverit's Avatar
I will double check when I get home. I checked it once. Panic button doesnt even work though. Thanks for the feedback
Old 03-13-2020 | 09:32 AM
If the panic button doesn't sound the horn, pushing twice won't either. (more than likely)
I'm guessing there is some compromised wiring under your dash. With the radio being disconnected I'm thinking the previous owner had more than a custom radio installed, something that included theft deterrent. When it came time to sell, he removed all that and just stuck the old radio in without reconnecting anything. Just a guess on my part, but likely what's going on.
Not saying it's the radio, but the dash wiring.
Old 03-13-2020 | 10:05 AM
I'm wondering if the PO bypassed the BCM for the horn?
Could splice the 2 tan wires to do it.
Old 03-13-2020 | 10:06 AM
jjoverit's Avatar
ok thank you. Kinda what I was thinking also. Will dig deeper into it.
Old 03-13-2020 | 10:56 AM
jjoverit's Avatar
I was actually tracing the plug from bcm up to the top of dash then it got dark. It looked like it headed toward drivers side. Looking for splices. I am going to remove cover under steering wheel and look there, and under dash. Thanks for diagram.
Old 03-13-2020 | 11:42 AM
Before you go too far in dismantling the car, have you tested the actual horn ? (or did I miss you stating that you have)
What I mean is, does the horn sound when you push on the steering wheel horn button ?
Old 03-13-2020 | 11:44 AM
Post #4
Old 03-13-2020 | 03:53 PM
I would look for the tan wires on one of the BCM connectors; one on the C1 and one one the C2. The one on C2 is the wire that the BCM control the relay with. If a pro installed an alarm system that's where it would be.
Maybe the PO did not read the Owner Manual and thought disabling the horn was the way to stop it from honking when they opened the door.
