Alturnative Fuel E85????
Originally Posted by zwede
Mike: Note the keyword "methanol". Totally different animal. The fuel system is ethanol compliant, not methanol.
Originally Posted by SoCalHHR
From the Manual:
...However, E85 (85% ethanol) and other fuels containing more than 10% ethanol must not be used in vehicles that were not designed for those fuels.
![Confused](https://www.chevyhhr.net/forums/images/smilies/icon_confused.gif)
I'll try again. :)
The original post said ethanol would damage the fuel lines/tank/etc due to corrosion. I posted that ethanol will NOT damage the fuel system as the materials used are ethanol compatible.
However, you can't run the HHR on E85 because E85 requires a richer mixture which the HHR computer and injectors are not setup to handle.
This is in line with what the manual says also.
A Crazy Canuck
Fuel Economy - Hypermiling
23
01-11-2013 06:29 PM
