am i the only one who???
Old 12-18-2007 | 12:21 AM
STREET STYLIN' HHR's Avatar
either bakes nice and golden brown, or is freezing cold in the hhr. i can ever get a nice climate going on in there. and the two little circle vents on the sides of the dash do not help the situation at all...
Old 12-18-2007 | 12:22 AM
xzombiex66's Avatar
lol im the same way man im either burning up or freezing never am i just right.
No probs here, but then again the AC is always set to it's coldest temp here in Miami.
Old 12-18-2007 | 12:23 AM
xzombiex66's Avatar
haha thats just so funny, lol why dont you just candy coat the situation a lil more
Old 12-18-2007 | 11:16 AM
Old Ray's Avatar
Now that you ask, this is the seconded new vehicle (2004 F150) I have had that the floor heat air control is terrible, hard to get your feet warm in the winter time without overheating upper cabin air but I thought it was just me, then I just got a new Ranger (An old platform design obviously) Great floor heat just the way it should be. Bad engineering in the HHR I would say.
Old 12-18-2007 | 12:27 PM
Black Rose's Avatar
I find that when you have the bi-level set (air up top and at the feet), there is hardly any air going to the feet area.
Have to set it to floor only to get the feet warm, and then switch it back.
Old 12-18-2007 | 12:35 PM
mizzouHHR's Avatar
What I do is close the vents on the passenger side and turn on bi level. When I start to get warm I switch to floor only. Then, when I get warm I turn down the temp to 3/4, then to half. Usually this keeps it rather comfy for my journey to work. And since I travel to work alone, I can get away with keeping the vents on the pass. side off. I've noticed that the heat coming out of the vents is quite hot, so turning the temp down a bit really helps to keep it from roasting me.
Old 12-18-2007 | 12:48 PM
Firewatcher's Avatar
I usually start either with defrost or dash vents. Then I switch to the foot mode. Because I have the temp cranked all the way, a trick I learned is to crack the window open about 1/4". This pulls the heat from the floor up into the cabin. After that I switch the fan to low, cut back on the temp control, and make my way merrily along. When I vacation in Florida, I always use the 72 degree setting in my sister's van.
Old 12-18-2007 | 09:31 PM
Markiemark's Avatar
My model has this larger nob, with half red & half blue, which adjusts my temperature of either heat or coolness.
Old 12-18-2007 | 10:25 PM
thirdgenz28's Avatar
I did'nt have any problem this summer, either the windows down or the A/C on (for the two days a year that we need it).
This winter finds me switching from floor to bi-level to defrost, but no complaints yet.
