Another hhr ecotec with missinhg / broken timing guides
2011 hhr 2.2 80000 miles put it in the shop for engine noise so far they have found 1 missing and 2 broken chain guides been using 5w30 napa full synthetic oil change 6000 miles they dropped the oil pan looking for the missing guide parts.
Timing chain has the front guide , the one that breaks at the top bolt, and the tensioner guide.
I use the Cloyes kits
9-4201SA timing chain kit, you don’t need to change the VVT gears in the cam shafts
9-4202S. Balance shaft chain kit
and the Melling 5499GMB front tensioner upper bolt replacement bolt
And are they replacing the crankshaft/harmonic balancer seal?
if they want to be through, use the AC Delco seal , I’ve had Felpro and a Durlast seal fail after a year or so.
Are they replacing the camshaft and the crankshaft bolts? GM recommends they be replaced.
This explains the upper front guide bolt issue
