another oil question
Old 12-30-2008 | 04:43 PM
lokwaidid's Avatar
ok, i have a stupid question. with synthetic oils being able to last alot longer, i have always wondered if there is a problem with the filter lasting as long as the oil without clogging up or at least slowing the flow a little. do you need to get a better filter or is the basic gm filter good enough? i have a 09 ss with only 1300 miles.
Old 12-30-2008 | 04:44 PM
ChevyMgr's Avatar
GM's testing says it is and they backed that with a 100,000 mile power train warranty.
Old 12-30-2008 | 06:21 PM
catdaddy137's Avatar
so,
it has synthetic from the factory? and do i need a special tool for the filter? i plan on using the gm filter and i will probably buy them from my local dealer. even though this is a small amount, i try to spend my money in my town. i say this because i have thought about ordering a case of them online if i found the right deal. this should also eliminate any possible warantee issues.
Old 12-30-2008 | 06:37 PM
1Panel2NV's Avatar
There is a socket that makes it a lot easier to get the filter on and off. Mine is made by Lisle, I got it at Sears I believe.
Old 12-30-2008 | 07:12 PM
Lake Runner's Avatar
Napa has the oil filter socket 32mm 3/8 drive. PN. SER 3932 $10.84
Old 12-30-2008 | 07:31 PM
diskullman's Avatar
Amsoil is the synthetic oil that preaches extended drain intervals. They have always suggested high quality filters, and they recommend a filter change halfway through their extended drain intervals. I think they suggest no more than 12,000 miles on a filter.
Old 12-30-2008 | 07:44 PM
the guys at napa
said they had no knowledge of that tool , this was a few days ago , before i read this. thanks , now i can go back , with a part # for them. THANKS TO ALL THE OTHER REPLIES ALSO
Old 12-30-2008 | 08:30 PM
oneton's Avatar
Here is the napa site with the part
http://www.napaonline.com/NOLPPSE/(S...Dn=0&Dk=1&Dp=3
Old 12-31-2008 | 10:11 PM
catdaddy,
The socket comes as part of a kit, PN SER 41830, which contains a 27mm, 32mm and a 36mm socket. They usually have this kit in stock, lists for $37.39. I had my local NAPA order just the 32mm PN SER 3932 for me and they had it the next day. Still was cheaper than online and no shipping cost, $11.84 total.
Old 01-01-2009 | 03:10 AM
halfpanel08's Avatar
i just use a 1/2 rachet and 1 1/4 socket.. works everytime
and syn. oil is the best. i run mobil 1 w/ gm factory filter
