Anyone use Quick Jack?
Old 04-19-2018 | 07:06 PM
Nope never used one, I’m thinking the Quick jacks would be in the way , to drop the fuel lines or the tank, to get the exhaust down, I’ve used a jack and jack stands for all my years wrenching at home in me driveway, a heater would be good.
Old 04-21-2018 | 11:25 PM
It's not for me, I prefer the floor jack & stands.
Old 04-23-2018 | 03:08 AM
SwissHHR's Avatar
Which are the best spots to put jack stands under, in the front and rear?
Old 05-01-2018 | 04:58 PM
I used the pads just behind the LCA bolts
and the pivot bolt bracket by the rear axle
Old 03-08-2020 | 03:29 AM
dougcjohn's Avatar
Originally Posted by jaskispyder
Anyone buy a Quick Jack for their HHR? I have multiple vehicles and I wanted to see if someone bought one of these and which model fit best. The HHR would need an extended version based on the data from the company.
Since the HHR doesn't have typical lift pads, I would be raising on the pinch seam, and is there any reason I have to raise exactly at the location were the jacking points are or can I come in 6" on each end? (They sell a pinch seam adapter).
quickjack.com
Thanks!
Old post... Still On? Looks like last post in 2018.
Did you purchase the QuickJack? Which model? How do you like them?
I recently ran across these Quickjacks, to me they look outstanding!
Ordered the 7000XLS to use with my SUV, Truck & HHR’s.
Easily meets mount points on all my rigs and can extend 6” if needed with optional rail.
Clearly Not intended for “Shop” usage that has ample ceiling height or multi-stalls, I don’t view as a 2 Post alternative.
It’s a “home” garage solution, for normal standard garages in height and size... great alternative or supplement to jack stands.
Live in a recent developed neighborhood, small 3 car garage that’d I’d call a 2+ garage, with lower ceilings. If still lived on rural farm with 60x100’ Pole barn & sectioned heated concert floor, the QuickJack wouldn’t be considered. Had a nice Ag pit & above ground hoist.
(New Wife, new house, less yard, older needs... but do miss that pole barn & open scenic view, not the 12 hr mowing).
For it’s intended usage, lifts 21” at the ”lock”... safe & secure. You “could“ even disconnect the hydraulics once locked as jack stands.
At 21” Lift - Plus Blocks; that’s a lot more shoulder room than using 3-4 ton stands; plus I personally feel more safe than 4 jack stands. The optional height blocks take up the excessive clearance or provides ample room between stands & undercarriage to access lines or clamps. They can also be used width wise Ft & Rr, to open center if needed.
The ability to easily remove off floor when not using, hang compactly on wall, frees up garage for other uses... or normal garage parking; can also toss in pickup and use at other location. For exhaust, brake, suspension, clutch & tranny... wheels or simply lifting up for detailing / polishing; nice lift. Particularly nice if doing something from both topside & underneath, easily lifts & lowers to help with access.
Not tossing the low profile jack & stands, but they’ll be used less for certain tasks.
These would have been very nice back in my 70’s muscle car days in Dad’s Garage.
https://www.quickjack.com
https://www.quickjack.com/compare/specifications/
https://www.quickjack.com/accessories/
Old 03-08-2020 | 08:19 AM
The OP has not been back since April 2018. Doubt you’ll get a response.
Congrats in your purchase, take pictures when it arrives, and post up an unpackaging and setup information
Old 03-08-2020 | 10:39 AM
dougcjohn's Avatar
Yep, noticed OP hadn't posted, thought maybe if received a email notice to his post he might re-visit with an update.
I'm looking forward to seeing & using these... older I get, the more room underneath I appreciate. LOL!!
I'm counting on these being easy setup, looks like the most time consuming is pushing them into position. The 7000lb rated model is 98lb per side, so it's certainly not like grabbing a 6lb jack stand.
As indicated, garage small, so it's a bit congested too. I'll take some pics along the way... but may look pretty cluttered. Building a 2 story shed is on my list, currently dealing with the town's "code" on yard structures.
Old 03-08-2020 | 11:56 AM
I hear ya, my shed is under my back deck, so only 4 feet headroom, I stood up to early in May 3, 2013. I’m still dealing with the concussion issues, and Dad always said I had rocks in my head! I checked into these and the shipping up to my place is prohibitive to that idea. So, it’s my trusty HF 1.5 ton aluminum jack and 4 , 2 ton jack stands.
Old 03-08-2020 | 02:57 PM
dougcjohn's Avatar
Dang, you must have really did the job on yourself... sorry to hear that, those hurt the worse!
Also sorry to hear they're charging shipping north of the border. They offered me free shipping and $100 discount code... which considering the weight, pretty good deal. The only gotcha, you're not taking them up on Satisfaction or Return... cost to return wouldn't be worth it.
As a bonus perk... a positive review posted, they'll send the a free accessory "jack pak" for free... $100 buck bonus.
https://www.quickjack.com/accessorie...ak-power-pack/
Have you tried them lately... ask for Donna, she might have some bennies she can offset shipping with... but weight to CA is probably pricey.
Old 03-08-2020 | 11:17 PM
Lethal Tendencies's Avatar
I have the quick jack. Love that thing. Easy to use. Great for brakes, tire rotation, suspension work. One of the best things I ever bought.
