Arm rest
Bonez- Peep this link. EZ fix. https://www.chevyhhr.net/forums/gene...too-far-62610/
Key search words I used was: Arm Rest Mod
I did find this remedy,
https://www.chevyhhr.net/forums/how-...armrest-14327/
hiding in the darkness of the archives in the basement on the bottom shelve.
Yep, that's where my link leads to, by way of another link. Good stuff still stashed away, just need to use the right key words in the searches..
My armrest is still good as way back when I did this mod. Definitely EZ fixable.
Thanks guys, took all but 5 minutes to do, Works perfectly now. The armrest had a little wiggle but the bolt was super tight, looks to be a spring washer that worn down a bit so I flexed it a little more and installed, seemed to do the trick, I did look for an additional washer but didn't have one with a big enough center hole so just flexed it a bit and it worked.
