Auto Govern
If its like any other GM product..once you pass 3/4 throttle position your locked out of 4th..another way to look at it..your in passing gear! You might be able to install a bypas switch to the lockup converter so it works in 3rd which will give another 200 rpm or so unless it requires (and probably will) a tuners help to reprogram it.
