Automatic or manual
Old 12-13-2019 | 03:27 PM
If "I" locks out OD then I don't think you would get near a speed limiter setting. Or maybe this is a regular LS, LT thing ?
Pretty sure there is no speed limiter on the SS.
Old 12-13-2019 | 04:57 PM
Blue_SS's Avatar
I never found a speed limiter on my SS manual. You get limited by road conditions and the aerodynamics of it first.
Old 12-13-2019 | 06:48 PM
Perhaps it’s a rev limiter not a speed limiter, that seems logical for an automatic with launch assistance
Old 12-14-2019 | 03:18 PM
Blue_SS's Avatar
I think both do have rev limiters. No-lift shifting is fun, too, but I mostly used it for 2-3 shifts on highway ramps. You can easily merge with traffic quickly. hehehe You have to concentrate to do it, though. That habit of lifting to shift is deeply ingrained.
Almost like driving a RHD manual. See which hand moves to shift the thing... Probably NOT the left, unless you really focus on it.
Old 12-16-2019 | 03:30 PM
prod's Avatar
Top speed is supposed to be limited depending on the factory equipped tires, for liability reasons.
My LS is 110mph, but I dont think I will ever verify it personally.
Rev limiter on the SS was 6300rpm from factory, 6500rpm with the GMPP upgrade.
Old 12-16-2019 | 04:25 PM
Originally Posted by prod
Top speed is supposed to be limited depending on the factory equipped tires, for liability reasons..
I've never heard that anywhere before, but is interesting. Is that documented anywhere?
Old 12-16-2019 | 05:43 PM
prod's Avatar
It was talked about in a thread here about 10yrs ago, thats all I remember. It could be wrong I guess but probably difficult to verify.
My quarter mile trap speed in a stock LS 2.2 was 89mph, so Id need a pretty long hill to prove it. :p
GM says the top speed for an SS is "over 150mph" so that would also be a challenge. 155mph is a common setting for speed limiters in europe, even in higher performance cars.
Old 12-16-2019 | 07:06 PM
I don't know why it took me so long to notice this thread was in "pictures and media" or why it was there in the first place. It is moved now.
Old 12-16-2019 | 07:18 PM
There is a RPM limiter for when it is not in gear, anyway. Not sure about when driving.
You would be hard pressed to find tires with a speed rating less than S (112 MPH) supplied by any factory. https://www.ntb.com/info/a20022/what...e-speed-rating
Usually, that is a function of the wheel diameter.
If the top speed of a SS is over 150 MPH the stock tires would be rated V, W, Y or Z following that logic. Most tires I've looked at are H. Never looked at SS tires.
Old 12-18-2019 | 10:22 AM
WoodysMobile's Avatar
Top speed
Occasionally on a "long and lonesome highway (sic west) of Omaha..." I have been able to reach the limited or ecm governed speed in a few vehicles.
Can't write all the details (protect the guilty) but based on experience I'd say an average GM vehicle shuts down at about 104-106 mph. Slow down back below the number and normal functions return. The performance models excluded as I haven't tried in these vehicles.
