Avg MPG not resetting
Could not find this issue in any other post. My Avg MPG is not resetting. I noticed it went from 23.5 to about 20.4 for no reason and tried a reset. No workie.
Any ideas?
Any ideas?
Does the button cycle the displays? If you hit it will it go to show you tire pressure, odometer, etc? If not then it's a problem with the button and if so then it's a problem probably with the software.
