B&M Shift Plus
I put one in the 96 4L60E I had in my truck. Personally I wish I had not. For the main reason, I did not like that fact you have to splice into the factory harness to install it. That is just begging for issues down the road.
Plus it wasn't that great of a "shift kit".
I have had one for several months now with no problems. More line pressure on the clutches means less slip, so less wear. I have ran manual shift kits for years and never blown a transmission. This electric one is doing fine as well.
Smooth shifts are enabled by gradually changing from one clutch pack to the other, leaving both engaged longer than needed.
Small engines would be better off with Constant Variable Transmissions.... no shifts, smooth power through a greater ratio range.
Hey, Ezeerider, what happened with the shift kit? I am curious to know. I have my car tuned, but once it is done, there is no way to adjust it. So I would also be interested in the kit. (Plus I love the idea of being able to add a B&M decal to my collection )
