Backup Light Switch
Old 02-16-2022, 09:55 AM
New to me HHR's Avatar
Backup Light Switch
Where is the backup light switch located on an automatic tranny?
The backup lights work going from Part to Reverse but intermittent from Drive going into Reverse.
Thanks
New to me HHR is offline
Old 02-16-2022, 10:07 AM
Post #9 has a schematic
https://www.chevyhhr.net/forums/gene...-lights-61397/
Oldblue is offline
Old 02-16-2022, 10:24 AM
Thanks Oldblue. The problem could be in the park -neutral switch from the wiring diagram. What is the exact location on the tranny of this switch? Easy to access?
Thanks
Old 02-16-2022, 11:37 AM
It is where the shifter cable connects on top below the fuse box.
donbrew is offline
Old 02-16-2022, 11:42 AM
Is it easy access to remove and replace?
Old 02-16-2022, 11:47 AM
Neutral switch requires an alignment tool, perhaps it’s easy just kinda hidden below the fuse box , I will look into a how to, there’s something about it here somewhere
Oldblue is offline
Old 02-16-2022, 11:50 AM
The tool is for aligning the switch, which sounds like the problem; you might try eyeballing adjustment.
donbrew is offline
Old 02-16-2022, 11:58 AM
Post #40 mentions the switch in this thread
https://www.chevyhhr.net/forums/driv...e-62657/page4/
But read on to see how Steve resolved his alignment
Oldblue is offline
Old 02-16-2022, 12:10 PM
The picture helps to recognize the actual part and location. Hopefully it needs a readjustment using my eyes as donbrew stated.
I miss the days when these type of switches were mounted on the steering column.
Old 02-16-2022, 12:24 PM
fastsuv's Avatar
I read about another method that people used to align the switch, though it wasn't specifically an HHR switch.
The method goes like this:
1) Put shifter in reverse. (Car NOT running)
2) Activate parking brake (so car doesn't roll)
3) Loosen the bolts holding the switch down. The bolt holes are elongated to allow some adjustment room.
4) Turn switch clockwise and counterclockwise to find the range where the backup lights are on
5) Put the switch in the middle of the range and tighten screws, making sure switch doesn't rotate while tightening
I never tried it, but it sounds like it would work.
Steve
fastsuv is offline
Quick Reply: Backup Light Switch
