Battery...
Old 08-05-2010 | 12:09 AM
daddy2isaiah04's Avatar
Battery...
I was just check my HHR out a little today, and when I was checking the spare to make sure it was in good shape, I noticed that I have a battery in the spare tire compartment of my car. Is this normal, because I also have a battery under the hood? I know that this HHR used to be a rental car for a local company here where I live, could that be the reason? Is it supposed to have two? If you know anything about this, please let me know. Thanks!
Old 08-05-2010 | 12:19 AM
All HHRs have battery in rear as yours.. Normal.
Under the hood you are looking at the fuse box cover, beside it does have a red + cap, that's where you can charge it.. And on the driver side strut top is a nut marked - for a ground ...
It's the remote battery access..
Old 08-05-2010 | 12:23 AM
If you try to jump start the HHR using what appears to pos and neg on the fuse box cover you will blow the fuse for the power steering. Use the above method using the strut top for neg.
Radco
07-09-2017 11:02 AM
HMHHR
06-22-2012 01:27 AM
Lee3333
Maintenance and Upkeep
07-17-2011 10:57 PM
longhornss
02-27-2009 02:15 PM
Lee3333
02-17-2008 03:39 PM
