Battery
Old 03-23-2020 | 01:18 PM
Blue_SS's Avatar
Originally Posted by Cat Man HHR
It looks like the electronics are very sensitive to voltage loss.
I would think the 130 amps the alternator can put out is sufficient.
Going below 12.4 volts when the battery is at rest looks to be a warning sign that sensors and the like can act up.
This is the problem. Voltage sensitivity. And, it has gotten a lot worse in the years since. When some module decides the voltage is too low, it can throw a code, or just act unpredictably. That threshold is a lot higher than you might think, too. Years ago, you just needed enough to get it started. Now all the modules need to be happy.
New cars today throw codes saying Module A can't communicate with Module B, and there becomes a pile of codes, and it can be hard to sort out. For example, if the BCM decides voltage is too low, it faults. Then the ABS module says it can't communicate with the BCM. Once the ABS is faulted, your backup camera is faulted and your parking assist, etc... So, the first thing to do is get the vehicle on stable voltage, and then see how many of these are still active. The faults come easier now in an attempt to keep the modules from getting flaky.
Old 03-23-2020 | 10:14 PM
Yep, sometimes I miss the simpler times.
Old 04-01-2020 | 07:25 AM
Chowser's Avatar
Broke down and bought a new battery for my daughter's '07 HHR. It still had the original battery in it. We're at 95k miles and I just found out she's been sticking cheap 87 octane gas in it. I told her if she doesn't want to spring for the premium then get the 89 because the last owner used 89 for the first 94k miles. She's got the 2.4L engine.
Old 04-01-2020 | 10:09 PM
Seems the OE batteries really last a long time. I feel it is because it's away from engine heat. Mine was 11 year old & still testing good. I was leary heading into winter so I got a new one.
I have the 2.4L also, & have run 87 in it, the computer will de-tune the engine. but mine seems happiest running 89 at least, & I only run 100% gas.
firemangeorge
11-21-2019 03:24 PM
Britjoe
Canadian Mid East
01-04-2015 10:48 PM
jeff schaffer
2.2L Performance Tech
09-08-2013 02:50 AM
JustinD
11-04-2011 04:02 PM
Lee3333
09-11-2008 10:34 AM
