Best lift points for floor jack?
Old 10-02-2018, 06:47 AM
aradmahogany's Avatar
Those areas with the arrows point to the pinch welds that your emergency jack is supposed to go. If you are using a floor jack like a 3 ton or so it should slide behind that onto the frame of the car. I jack mine up where the posts would go on a lift
aradmahogany is offline
Old 02-28-2019, 01:53 PM
fanbelt.1's Avatar
My first time doing any maintenance on '08 HHR SS. Tired of dealer ripping me off. I worry about bending the eggshell-thin unit body sheet metal. So, I just want to be sure. If I position an 8" length of 2 X 4 just inboard of the emergency jacking point, will that prevent any permanent deformation? Also, I'd like to lift both sides of the rear at the same time, so is there a safe adjacent place to place a jack stand? Thanks!
fanbelt.1 is offline
Old 02-28-2019, 02:50 PM
Cat Man HHR's Avatar
In the rear just jack up in the middle of the beam. No you won't bend anything.
I jack the front close to the rear of the tires on the subframe on each side.
Please use jack (axel) stands to support your car for safety.
Cat Man HHR is offline
Old 06-09-2021, 02:18 PM
MN Murph's Avatar
Incorrect info removed
I removed that info.
MN Murph is offline
Old 06-09-2021, 03:10 PM
Good, please confirm your information prior to posting.
Oldblue is offline
Old 06-09-2021, 06:41 PM
It came from a thread here, he had linked to it.
RJ_RS_SS_350 is offline
Old 06-09-2021, 06:58 PM
From in here, post #8 from ChevyMgr. A generic photo in the GM booklet , hmmm.
https://www.chevyhhr.net/forums/gene...or-jack-14470/
Oldblue is offline
Old 06-10-2021, 11:20 AM
MN Murph's Avatar
I read further in this thread where the diagram is (#8 post) and saw disagreement
rookie mistake
MN Murph is offline
Old 06-10-2021, 05:32 PM
I don't understand the angst. I always jack on the seam welds never bent one. Think I-beam, or why are floor joists set sideways instead of
donbrew is offline
Old 06-10-2021, 06:46 PM
The scissor jack that comes with the car has a groove in the saddle to accommodate the rib that protrudes down from the lifting point. If someone wants to use a different jack, they could make something with a similar groove if they don't want to bend the rib.
I doubt that bending the rib compromises the structural integrity of the vehicle at all.
I'll use the engine cradle rear bolt, the one shared with the control arm.
Some HHRs didn't come with a spare tire, just a bottle of goop. They probably don't have a jack either.
Quick Reply: Best lift points for floor jack?
