Best place to tap an ignition wire?
Old 12-21-2020, 06:04 PM
hhrumadbruh's Avatar
I have a switch next to the shifter on a custom switch panel i made, wire is ran near the gas pedal and up into the main wire grommet to the fuse box under the hood.
I need to tap into an ignition wire so this device stays on whenever the car is on. It's already on a relay.
I have the directtechs print out but it only lists the steering column and I prefer not to touch that.
hhrumadbruh is offline
Old 12-21-2020, 06:59 PM
Since you don't say what the switch is for or how much amperage it needs, then it's hard to recommend where/what to tap into.
Me. I prefer to tap accessories into their own slot. Check one of the fuse locations marked "empty" and see if they have power on the incoming side. If so you could use one of those.
Disclaimer: One of those empty slots shouldn't be used.(can't remember which one) It will disable the rear hatch opener if a fuse is put in that slot.
Anyone remember which 1 that is ?
firemangeorge is offline
Old 12-21-2020, 07:02 PM
Its on a relay so any 12v will work.
I tapped the pink wire on interior passenger fuse box.
Old 12-21-2020, 08:07 PM
Fuse #11, underhood.
RJ_RS_SS_350 is online now
Old 12-21-2020, 10:06 PM
Any of the "spare" fuse position on the BCM are switched and on the RAP relay. The last thing in the world you want to do is tap into the IGN.
This is the 21st century, learn to live with it.
donbrew is offline
Old 12-22-2020, 07:28 AM
Lonwane's Avatar
Why would you 'tap' into a wire when you can go directly to the fuse box and have a dedicated curcuit?
Modern cars don't like their signals disrupted are altered.
Especially HHR's, since that is what we know.
Lonwane is offline
Old 12-22-2020, 09:19 AM
WoodysMobile's Avatar
Connect in the fuse panel inside the car
Can't agree more a dedicated circuit is the way to go. Why did you go under hood?
I'd expect you can find the power source (switched or unswitched in the interior fuse panel.
Or you could run a wire all the way back to the battery area.
WoodysMobile is offline
Old 12-22-2020, 11:34 AM
solman98's Avatar
This is the ignition source I used on my 06. Passenger side of the console. It is a hot ignition on slot.
solman98 is offline
Old 12-22-2020, 11:49 AM
The device I'm powering is in the engine/bumper area. The switch to control the relay was next to the shifter. This was mentioned for wire length reasons and was why I wanted to find something near the kick or interior fuse panel.
It's on a relay so I don't believe it's going to draw much power from any lines. I used the pink wire in the passenger interior fuse box. Seems to work perfectly.
Is there a diagram of empty slots that can be used as ignition switches?
I don't see the point of running a wire to the battery. I already have ran 2 16awg power and ground wires from the battery up to the shifter area for switches and volt meter.
Old 12-22-2020, 11:57 AM
cause I'm old school I guess.
So I should find an empty fuse and test it for ignition instead, then add a fuse tap to it?
it's only a relay turn on wire. I can't imagine it putting any significant strain on anything.
Under hood fuse box would be much easier to work with since my relay is right next to it, and I've tapped off the red plastic cover 12v+ bolt next to it for a few in line fuse holders for the relays. Only reason the wire was in the car was for a lighted switch but that's obsolete now.
Quick Reply: Best place to tap an ignition wire?
