Blind spot on the right side.
I've had this thing a year and every time I look to the right back area, the passenger seat headrest is right in the way. Folding it down was a pain as everyone usually throws something on the seat.
So I tried leaning it back and this is great. No all the way back but enough for clearance. Just never gave it any thought before other than it was aggravating.
I had many blind spot when I bought the HHR but with time behind the wheel they have all vanished.
You want a real blind spot drive a Fiero coupe with a wing and Indy Rear deck scoop.
I have lost Semi's in that car on the right side.
Yup, Or adjust your mirrors as suggested .....http://www.smartmotorist.com/car-acc...correctly.html...This way I can keep my headrests.
If the fronts are ther problem it is time to learn how to use a mirror.
If you remove the fronts then the A, B or C pillar will be in the way. Just need to adapt to the vehicle and not be to overly sensitive to the things around you.
If you can adaprt to the A pillar in a HHR you can adapt to anything.
