Braking
Old 10-31-2019 | 12:37 AM
Flyinmech's Avatar
Braking
Hi, again guys with another question, just remember I am a newbie. I am the proud owner of a 2006, and it seems weak on the brakes. I know this has shoes on the rear, but is this normal. Or do just have to press harder on the pedal. I found for the throttle you have to get on it to get going.
Thank you
Old 10-31-2019 | 02:18 AM
As long as the pads and rotors are good on the front, about all that should be checked is the rears, which MUST be adjusted properly. The self-adjusters on the rear don't usually work that well, so many make it a routine maintenance item to adjust the rears manually.
Old 10-31-2019 | 07:23 AM
X2, adjust the rear drum brakes every oil change.
If you count more then 3 clicks as you engage the e brake , you need the adjust the rear shoes
Old 11-02-2019 | 03:30 AM
wren's Avatar
On my wife's '08 I've not been thrilled with the braking. Takes far more pedal pressure than our other vehicles. I've spiked the brakes on gravel and am getting braking on all four wheels.
Now, I could be wrong on this but the feel is that the car has more weight than the brakes are comfortable with. Just my opinion.
Wren
Old 11-02-2019 | 08:16 AM
Lonwane's Avatar
Gravel is not a good place to check the brakes as there is no friction between the 2 surfaces, rubber/road.
X3 on adjusting rear brakes. As one poster said "every oil change" and if your still concerned take the vehicle to a reputable brake shop and have the system checked.
Old 11-02-2019 | 09:10 AM
Then again, the upgrade to larger diameter rotors from the 2008 thru 2010 SS non Brembo only requires the caliper brackets and 11.6 inch rotors.
I’m about to do this upgrade in the BlackSwan, here is the how to
https://www.chevyhhr.net/forums/brak...ard-hhr-42938/
Old 11-02-2019 | 09:25 PM
Don't forget that Dot 3 brake fluid should be thoroughly flushed, I do mine every 5 years.
But Auto parts stores sell a test kit, that you dip a test strip into the brake fluid & what color it changes to indicates the fluid lifespan used.
OC_HHR
05-28-2015 07:17 AM
toolman101
11-15-2014 07:44 PM
OldSchool57
18
05-01-2012 03:33 PM
Fugazi
01-30-2010 01:16 AM
rbabiak
02-12-2009 08:58 AM
