Building my version of a SS Panel
Old 09-20-2007, 02:16 PM
Snoopy's Avatar
Originally Posted by hvrod
Schedule of Panel Transformation"
obtain Panel from Dealer
De badge vehicle imediately
* Total Exhuast system removal / replacement
* Vehicle lowering
* 4 Wheel disc conversion
* Sway bar installation
Painted mud flaps install
Tires/wheels change
* Injector/Harness replacement
* Stock intake removal / replacement
* ECM sent out for upgrade
Engine Dampening install
(The above items * make this a SS version based on the GM VP making his statement what makes a SS version)
Engine compartment components mods
Headlight / fog lamp replacement blubs
Rear wiper system removal / t-handle install
Rear window accent details
Just a start..
It APPEARs the mods are the same as your current HHR. Are you planning anything different?
Snoopy is offline
Old 09-20-2007, 02:19 PM
hvrod's Avatar
Originally Posted by MOTRV8D
not to mention the drivetrain would have a 5 yr/100K warranty...
This would definite void the corrosion warranty. and dimish the collison stars on doing extensive body work to the vehicle.. Thats why I choose to let the factory to panel the vehicle..
hvrod is offline
Old 09-20-2007, 02:21 PM
hvrod's Avatar
No.... why change a good thing?
The only difference would be the vendors I'm obtaining the parts from is the difference..
hvrod is offline
Old 09-20-2007, 03:42 PM
Markiemark's Avatar
I think you REALLY should put SS on it!!
Markiemark is offline
Old 09-20-2007, 03:46 PM
hvrod's Avatar
Just don't like them badges...
Stealth is nice..
hvrod is offline
Old 09-20-2007, 08:59 PM
  #26
Markiemark's Avatar
Stealth is nice..
I was just messing with you!!!
Did you summarize the cost of transforming these mods (ballpark) vs. is there is a stated price on the SS, YET???
I know you are doing a panel and all, but just wondering!
Later
Old 09-21-2007, 01:12 AM
  #27
BigMOCats's Avatar
I don't see where you are replacing the grill and front and rear bumpers, or adding the PE spoiler. Now that would be a Panel SS.
BTW - clones kinda suck!
BigMOCats is offline
Old 09-21-2007, 02:11 AM
  #28
en0oNmAI's Avatar
^-- but nothing listed by the GM VP said you have to have a different spoiler or bumpers to be considered an SS model..
Look at the Camaro. LS1 z28 vs SS. Only real visual difference was the ram-air hood and some badges. Does it have specific front and rear facias and a spoiler ONLY found on SS models? No....
HVRod is going on the generalization that an SS model has to stop better, go faster, and turn better. He is accomplishing that. Those of you who keep berrating him are just not getting the point. So what if there's an SS version all ready coming out? He is making one for himself based on the GM VP's explanation. He already has his own version of what an SS should be. Now he is making a panel. Either applaud it or get off the high horse that this isn't a "real" HHR SS.
en0oNmAI is offline
Old 09-21-2007, 05:28 AM
  #29
misterjensen's Avatar
I really don't care either way, but I think what some people are thinking is that if he was going by definitions, he could add a wagging tail and floppy ears to the car and call it a dog. It's not a dog. By extension, some people are thinking that even if he mods his car by following the definition of what an SS is, it's still not going to be an SS... it's a modded LS or LT. Again, I'm not taking a stand, I'm just trying to explain what others may be thinking. It's his car and his cash; whatever makes him happy :)
misterjensen is offline
Old 09-21-2007, 07:59 AM
  #30
hvrod's Avatar
Later
Since I'm venturing this task on my own.. of course its going to cost more $$$ then GM.. Which are mass producing these items.
I can tell you one thing.... I bet you GM will still have a speed limiter on the SS HHR -- After my reflash -- I won't... And when I had my G35 Coupe.
When I had that reflash, the tuner found out that Nissan had also limited the throttle opening to only 80% so everyone was getting the full cabilities of it..
(Because it was fly by wire setup -- like the HHR) So a reflash will still do you good..
hvrod is offline
Quick Reply: Building my version of a SS Panel
