A/C output temp
Old 04-20-2008, 05:36 PM
Sunrise HHR's Avatar
Cool A/C output temp
Had a chance to finally use the A/C and it was cold but not as cold as I thought. What should the temp be comming out of the air duct's? On one of my cars years ago I thought it was around 40 degrees. Any Ideas?
Sunrise HHR is offline
Old 04-20-2008, 06:15 PM
afs9's Avatar
I'm wondering if what you feel is cold and what I feel as cold is different based on our geography??
I got the car on a weekend it was 107F and the AC has rarely been off since. I like it cool and there are times I think it is too cold!
So IMHO, I think it is cool enough.
afs9 is offline
Old 04-21-2008, 12:56 AM
Snoopy's Avatar
Can't tell you what the exact spec is for the HHR but..........
Several years ago, 54-58 degrees from the middle vent, with the blower on high and the a/c on "Max Cold" was the baseline number. Oh, that was with a 92 degree ambient, in park or neutral, with nothing blocking the front of the vehicle.
The temperature probe needed a 8 inch stem.
Snoopy is offline
Old 04-21-2008, 07:39 AM
A/C output
Thanks , will check with thermometor this week. It just does not seem that cold.
Old 04-21-2008, 09:26 AM
dbfruth's Avatar
Do you have it set to recirculate? I have found it never gets cold enough on the fresh air setting.
dbfruth is offline
Old 04-21-2008, 08:07 PM
SandyBeach's Avatar
I agree with dbfruth. Mine works best on recirculate but I run it in normal for a few minutes first. It cools down within minutes on a warm, humid, summer day in Florida.
SandyBeach is offline
Old 04-22-2008, 10:39 AM
irloyal's Avatar
All the automobile A/C guys say cold air blowing from the vent HAS to get down to 52 degrees minimum. If it isn't that low, you have a problem. They use a small stem thermometer to measure the temp and stick it right in the center dash outlet.
irloyal is offline
Old 04-22-2008, 10:56 AM
ChevyMgr's Avatar
If anyone wants to see the detailed procedure on how to perform the A/C performance test, PM me with your email and I will send it. I tried to post it but the file is too big.
ChevyMgr is offline
Old 04-22-2008, 11:08 AM
GCarp's Avatar
Generally, isn't the A/C efficiency based on the difference from ambient temperature?
Ex: If its 80° out, the A/C should put out say...50°. If its 90° out, then the A/C would put out say 60°?
GCarp is offline
Old 04-22-2008, 11:37 AM
ChevyMgr's Avatar
And you have to know humidity also.
ChevyMgr is offline
Quick Reply: A/C output temp
