Can The Temp Indicator Go Any Lower?
Old 01-21-2011 | 12:46 PM
Heritage High Roof's Avatar
The air temperature ranged from -29F to -41F early this morning. When I started the HHR, the outside temp display went to -22F and would not go any lower. Now that it is warmer (-15F), the display matches other thermometers.
Has anyone seen their indicator fall below -22F?
Old 01-21-2011 | 01:46 PM
ChevyMgr's Avatar
The service manual states the ambient temperature sensor has a range of -40°F to +140°F. But the air sensor resistance table states the lowest is -30°F. So it's either -30° or -40°.
Old 01-21-2011 | 04:13 PM
Rod Run's Avatar
HOLY CRAP!!!! I don't think I've ever seen -22 degrees....PERIOD!!!
I thought our expected weekend temps, where I live, of -5 degrees were considered cold
Old 01-21-2011 | 04:37 PM
I saw -18 when we were in Jasper Alberta it was cold
Old 01-22-2011 | 02:00 PM
rihan's Avatar
I had the same issue here in Moorhead the other night too. When I got off work the temp was -27, but the DIC would not go below -22. Maybe it just gives up?
Old 01-22-2011 | 04:18 PM
bassbase's Avatar
I think under -10 it should just say "damn cold".
Old 01-22-2011 | 05:13 PM
That would be a good replacement for "ice possible"
Old 01-22-2011 | 05:31 PM
Yeah if someone could hack the BCM we could have it say all sorts of things....Friggin' Cold...Forget It Buddy...Go Back Inside...Have Some Coffee...Are You Nuts?...Why Me?...I Have A Headache.....the possibilities would be endless.
Old 01-22-2011 | 06:53 PM
Old Lar's Avatar
I freaked out the first time I saw "ICE MAY FORM" on the DIC. I was up in Maine in December of '06, as it doesn't get below 32 very frequently in my part of Florida. I did figure out to work the heater.. a learning experience.
Old 01-29-2011 | 05:13 PM
JTKrupa's Avatar
It hit about -10 here a little over a week ago, and all I have to say is "DANG!!"
But seriously - does it really matter if the DIC drops below -22 ? That kind of cold is not fit for human existence.
Leemor
06-09-2014 07:33 AM
nybble
Mods - Interior
05-14-2013 08:41 AM
kornellred
08-26-2007 07:39 AM
joesblackhhr
2.4L Performance Tech
31
07-20-2006 05:28 PM
MikeX
04-30-2006 09:30 AM
