Car Cover
The garage works pretty good if you close the door before the neighbors cat gets in.
look in here one of the supporting venders must have that covered. https://www.chevyhhr.net/vendorindex.php
http://www.carcoverusa.com/Coverking-Materials.html
I use the silvergard cover. very lightweight and easy to stow away. Not really good for rain, but I got it mainly for protection against the Sun here in Southern California.
For those detractors that say covers will hurt the finish...sure it will if you just put in on without any prep. Before I place the cover on, I use a california duster to get the thin layer of travel dust off and quick detail spray for anything worse.
BTW Bonnie and Kevin, nice looking covered HHr Panel you have in the driveway :)
Be sure you use one that can breath, so it doesn't trap moisture against the car. I used to use a cotton cover, but that was really only for sun protection. Now my entire fleet is parked in a garage.
Hey Ramos,
Here's the link and our's is the Superweave Version with "ZERO" issues or complaints! You pay for what you get (unless you know someone ):
http://calcarcover.com/default.aspx
Thank's Daryl, as you notice we park against the wall to keep it away from our POS neighbors as much as possible inside the garage is even better
Best-O-Luck Ramos ,
Best-O-Luck Ramos ,
