Car won't move
Car won't move
Bought my car at 300000km put 20000 on it. It died one night wouldn't start. Took air filter out smacked it clean. Started without air filter but real rough. Changed oil oil filter now starts but won't Rev OR move when put into gear. Help please. It's a 08 chevy hhr automatic ls 2.2lt
A friend of mine figures it's the timing chain. Which scares the h*** out of me because that's a whole motor job
It's very high mileage. You should at least get the codes. Why buy it with that history? Maybe you got it cheap.
to the forums!
First of all, replacing the timing chain is not that bad of a job. You don't even have to remove the engine.
But yes, let's get the codes. You'll need to get a code reader, or tow the car to someone who can read the codes for you. Do not attempt to crank the engine over again. If the timing chain is to blame, the engine may not be ruined yet. But continued cranking may yet destroy it.
