cargo dome lights
cargo dome lights
My dome lights over the front seats come on when I open the front doors. But I can't figure out how to make the rear cargo lights come on when I open the back doors or the natch back.
They all work if I reach up and press the light itself;... but don't come on otherwise
I "assume" there should be a way so the system is set so the lights come on and go off automatically. What should I do to make that happen??
Since you didn't mention what year HHR you have, I'll quote from the owners manual of the 2006 model:
Dome Lamp
Your vehicle may have a dome lamp.
9(Off): Move the lever to this position to turn the
lamp off, even when a door is opened.
1(Door): Move the lever to this position to turn the
lamp on whenever a door is opened.
+(On): Move the lever to this position to turn the
dome lamp on.
Entry/Exit Lighting
The lamps inside your vehicle will go on when you open
any door. These lamps will fade out after about
20 seconds after all of the doors have been closed or
when the ignition is turned to ON. These lamps will also
go on when you press the unlock symbol button or
the horn symbol on the keyless entry system transmitter.
The lamps inside your vehicle will stay on for about
20 seconds after your key is removed from the ignition
to provide an illuminated exit.
If you don't have an owners manual, they can be downloaded here at - https://www.chevyhhr.net/forums/gene...s-manual-3074/
Dome Lamp
dome lamp on.
Entry/Exit Lighting
Yours seems a little different from page 167 of the 2007 owners manual:
the lamp off, even when a door is opened.
the lamp on whenever a door is opened.
The dome lamp and mirror reading lamps will turn
on if the lever is in the door position and the
instrument panel brightness control is turned to
the brightest setting. See Instrument Panel
Brightness on page 166.
on the dome lamp.
on the dome lamp.
The lights come on; you just have to push the light for it to come on.
To Whopper - yeah it is weird... only the rear part of the dome lights come on when I open the door... not the front part like you indicated it says in the book.
Puzzling
Puzzling
