cargo net/stupid question
#33
Okay! I too had a tough time figuring out the cargo net placement. NOW I know - thank you!
But, I wish there was a way to divide the cargo area in half; right half/left half so I can place grocery bags there and they won 't fall over on the way home from the store.
All this time I've been using 30-pk beer and 12-pk Coke cases to keep the bags upright but the cases slide around too.
#34
. . . well. I guess there needs to be two upper loops on each cargo area, side panel. One at the seat back and the other at the rear gate.
I thought to try and hook the forward upper (cargo net) hook to the seatback release knob but it may break it off.
#38
I use the 4 side hooks. The manual says to put the rear floor in the upper position; then paper bags can sit in the well and you can hang plastic bags from the built in hooks. Or, put the floor in the tilted position to really limit things. Or, use the hooks on the bottom of the floor to hang the net. Or, use the net as a hold down.
