Carpet kit for rear compartment
Were just finishing up the proto type for my panel, when done it will be one piece (aircraft grade 100% wool carpet) that will also cover the tiedown connections for a seamless look, we'll be able to make them for both models so one or two piece, let me know your thoughts if anyone is interested and I'll post pics in about a week
Make one that covers the entire floor with the back seats folded down. It should attach to the rear of the seats in a way that it protects the back of the seats from cargo scuffing and have some sort of "hinge" feature at the split between the seat and cargo floor.
As of now, there is nothing like this available.
Thanks for all the great ideas, the break point or hinge just might be doable. Were almost done the only area thats giving us a fit (no pune intended) is the radius on the corners by the lift gate, once thats done everything else is completed, its taking a little longer since business has picked up so it might be another week or so, but it will be perfect.
Thanks for all your input
felt?
i like ratracers pic...looks like ..felt ?....gm makes a rubber 1 , 2 pieces for the panel....the gm rubber should work great to keep anything , including wheelchairs , from poop sliding...they also got a cargo net for that , which could save your life.
