Caution possible carbon monoxide poison problems
The smell is from the kat converter and yes we know that it is odorless but if you smell that you have carbon monoxide . That said if somthing harmful that you can,t smell is there would you want your children riding in it. There is a lot of factors taking place and i sure mine is not the only one.
I know "old timers" with 10 year old Cadillacs that still have that smell....probably do to the way they drive. Oh, and they're still alive (although highly questionable) .
I think you are confusing the rotten egg smell in natural gas with your experience. In natural gas the smell is placed there to detect a gas leak easier. It is not the case with Cat converters.
I would venture to guess if this problem were as widespread as the original poster indicated, the US Dept Of Transportation would have info on the problem. Please see info I receive below via email every couple months or when things are added.
Also link to site is http://www.mycarstats.com/safetystation.asp
Murcaptan is what they put in natural gas and propane that gives it the smell, Now back to the exhaust problem In simple terms ,for those hot rod buffs that work on motors alot and and run them inside the shop with not very go ventilation also in the winter with the doors closed you get that bad exhaust fume smell make you gag cant breath, or just start your car put your nose in the tail pipe and breath, THAT is what is in side the car, that is what I smell.
i have noticed a weird smell with mine every now and then but havent thought into it. I think its just the engine burnin off new stuff. its just part of the breaking in period i think. I dont smell it anymore. also some of the fuel we have here has a different smell. and maybe the HHR has some weird exhaust set up i dunno
You have nailed it. I can smell most cars exhaust in front of me, some are way worse than others. I put the air flow on recirulate and the air clears within seconds. I wish the default was recirculate and then I would never have any issue. I just made it a habit to push the button as soon as I start the car. I don't think this is an HHR issue, it is pretty common.
Mine still smells from the pizza I bought last weekend. Boy, that upholstery sure hold smells. That may be why you continue to smell it after the car is turned off.
I've had my HHR 18 months and don't ever remember a smell.
