CGS in the winter.
Old 10-07-2007 | 04:47 PM
Money in the Bank's Avatar
CGS in the winter.
not sure if i should keep it on or not, winnipeg has some of the coldest winters in the whole country. due to the low temps i dont want to hurt the engine.
Old 10-07-2007 | 10:43 PM
Premiere07's Avatar
It wont hurt anything, the sensor will pick up the incoming air temperature and adjust the A/F ratio accordingly. Even if you had the stock unit you would still be breathing the SAME air. It will not matter.
Old 10-07-2007 | 11:14 PM
I know you get MUCH colder than most parts of the States but the computers should adjust.
Remember, the stock set-up drew fresh air from the wheel well so I'd think it would be even colder than from the engine area. Which is kinda the idea!
Old 10-08-2007 | 12:31 PM
sounds good. thx
Krash Kadillak
Tires & Wheels
0
03-20-2011 01:20 PM
Scrivs
09-12-2008 12:04 PM
oldschoolfreak
11-11-2007 10:29 AM
